I re-caped a untouched BM8000 recently. Everything went, for my huge surprise, very smoothly and I had all-ways in my mind that this is to good to me true, so it was not.
So I did the necessary adjustments on the two outputs with new trimmers from Martin.As the BM came with the older CPU unit where the metal cover is soldered to the PCB board I did not opened it and did not change the lonely cap in there.
I re assembled the unit and did a little test run with it, low volume for one hour- no problems. I had to attend other matters so I left the unit plug in, in standby. When I came back after 30 minutes or so the display was lit in center with T and some erratic numbers on volume and in radio channel display. But the unit was on standby. I pushed radio channel button and channel came on but the display was very erratic with flickering numbers but clear sound. No volume control and no response when truing to put the unit on stand by using stand by button. I took the plug of the socket and re plugged it 30 minutes later to find the unit in perfect working order.
So I think the Microcomputer PCB board has some problem. Has one of you here had the same problem perhaps and all ready find a solution or a suggestion where I should start?
Regards
Egon.
