beomaster 7000 speaker 1 or 2 selection
Hello all B&O vintage fans,
I have reinstalled my beomaster 7000 connected to 2 pairs of passive speakers. 2 beovox 3000 on the wall in room 1 connected to speaker 1 output, and 2 other beovox in the room next-door connected to the speaker 2 output.
Is there a way to select only speaker 1 or only speaker 2 when playing music ? via remote beo4 or master control panel ?
Default, all the 4 speakers are playing.
Thanks a lot for your help,
best regards
Eric
The mute button will mute only speaker 1. However what you clearly need is an X-Tra speaker kit which is a box that attaches via MCL cable to the speaker 2 outputs (you will notice there are 3 pins in each socket) and this will allow remote control of the system in a link room.
This is the box - seems an expensive example though!
https://www.ebay.co.uk/itm/Bang-Olufsen-B-O-MCL-X-TRA-Speaker-Kit/254815758978?hash=item3b5433ea82:g:YasAAOSwwaFf4y6M
Thanks Peter,
I have this box and the remote panel , but I never succeed to install it. I was hoping there was another simpler solution:-)
Maybee I'll give it another try.
Eric
Thanks A lot Peter,
I have this box and the remote panel, but I never succeed to install it. I was hoping there was another simpler solution.
Thanks anyway
Eric
