Beomaster 7000
Hi. I've just bought a beomaster 7000 - looks to be in good condition and is working. Where can I find n instruction manual for this? Also, will the blink 1000 which I have work with this, or do I need to get another control unit?
Andrew
Hi there,
Beolink 1000 will work fine. Instruction manuals are available onsite.
As you are a silver member you can access the manual for the BM7000.
Ben
To get the most from the 7000, you will need either a Beolink 7000 or maybe a MCP5500 - both these allow programming so you can use the system as a very sophisticated clock radio!
Sounds like it is in a.option 0.
Set it to a.option 1 or 2.
Turn of the unit, on the remote push
Sound
1
Store
