Guys, I need a help :( During maintenance work on my BM6500, I’ve drop screwdriver and caused short circuit with some sparks. In effect, the 2 way communication lost part of functionality. I feel like a fool, but accident is accident.
In general BM is working with Beolink 1000 and 7000 in one way mode. BL7000 is showing no contact for 2 way. Everything is set to Option 1.
Standby diode is responding to remote signals I mean blinking for accepting IR codes from remote and then blinking again for respond, so I suppose that sending signal is not proper/weak.
I’ve checked symptom with MCP too. Here MCP is not able to send/read anything. I’ve checked remotes with BM5500 and I’m sure, they’re working fine.
Then I’ve replaced front panel in BM6500… ant there’s still no contact. On processor board checked bad solder joints, replaced old capacitor and checked diodes. Cleared and checked NVRAM in test mode. IR and RAM tests passed correctly, but still don’t have proper answer from BM to MCP/BL.
I have no idea where find more issues.
I’ve a plan to replace all transistors on processor board, physically and reset IC2 by shorten 8th pin, but need some advice anyway, what else could be wrong.
Maybe some of you have not necessary processor board for BM 6500 to sell? Or whole BM for parts?
Thanks in advance!
D.
