Beomaster 6000/ beogram 4002/ beocord 5000
Hi, does anyone know for sure what process was involved in the finishing of the control panels of Beomaster 6000 quad/ beogram 4002/ beocord 5000?Was it an anodised process on etched aluminium or a brushed / linished lacquered spray paint finish on aluminium?Kind regards,Struer
Kind regards,
Struer
Yes, Bang & Olufsen knows.
And they won't tell.
Ha, thought you might have inside information
It is a coating. It isn't etched.
Underneath the coating the button panels are smooth. You can see that on some very worn button panels.
-sonavor
