Hello.
I have a problem with my BM5000/MCP5000, as they will not communicate together.
The MCP is from another BM5000, but should this be a problem?
Do they need to be "paired" before use - and if so - how is it done?
When trying to use the MCP, it just lights up the message "No transmission", and nothing happens.
The MCP has quite new batteries.
In the BM I did replace the C8 capacitor, 100uF, as it was way out of value.
Also the C38 in the IR transmitter circuitry was replaced, but that didn't help either.
All voltages in the BM5000 is OK and without ripple.
The BM itself works just fine except for the above, but it would be nice to be able to adjust bass and treble.
This seems to be done only through the MCP.
Did anyone experience something similar - or maybe just know, what can be wrong?
Best regards
Per
