I have been struggling trying to get one working Beomaster 5000 working out of 3 non-working receivers.
Two of them had failures in the PC board in the same trace leaving the rectifier. Must have been a design flaw in the PC board.
After repairing these, and finding what I thought were 4 good BF857 (TR108/208 and TR109/209) and four good Darlingtons (BDV64B and BDV65B) I had a spectacular failure which blew the lid off of the BDV65B on the right channel along with a nice puff of smoke.
I removed all 4 Darlingtons and am focusing on getting all the DC voltages correct before trying some new parts. I put some test wires in the base of each of these transistors.
Currently moving left to right, I'm measuring -40.6V, -40.8V, -40.8V and -40.8V on the base of the 4 Darlington transistors.
I also measured the collectors of the 4 BF857 and come up with 40.6V, -40.8V, 40.7V and -40.9V.
The only measurements that make sense are the 40V measurements on two of the BF857s as they have collectors wired directly to the 40V power rail. The others should measure -1.1V (same as the base of the BDV64Bs).
So the base voltage for all 4 darlingtons is about -40V when it should be around -1.1V. In other words, way off.
Does anyone have a suggestion of where to look for this? Both channels seem to behave the same way.
Jeff
