There is nothing on the screen. The unit BM5 turn on,disc spinning, fan working, but only 3 of 4 test led's are showing voltage .
Only the red light on the BS5 screen lights up. It does not blink, it's only light.
I tested a screen on another BM5 running and the screen works normally.
I also changed the disc from one BM5 to another and the disk is working normally.
Is the power supply problem or on the motherboard?
Is it possible to repair by replacing the condensers?
Thanks for the advice.
