I did when I first received the unit. Pressing Sound read out "--79" on the 4 digit display. I couldn't adjust the balance. Likewise the treble, bass, and loudness couldn't be adjusted either and had equally nonsensical readings on the display. This was an issue I thought I'd try and tackle later fearing it would be some microprocessor issue. . .
Anyway, I found a copy of the BM4500 service manual on line, and my mind was blown on what I was reading. This thing is way more powerful than just a receiver. The whole house control aspect of this system with MCL unit was something I was not fully aware of, and the system seemed like it was behaving like it was set up like a slave device on a whole house system. I'm still really fuzzy on how that whole system works, but I'll leave that mystery to another day.
After figuring out how to put it in Test Mode, all the microchips and memory checked out OK, I erased the RAM and restored the system to its default settings.
BINGO! I have sound from both channels, bass, treble, and loudness control! Balance reads '----' , treble and bass both read ' -- ', and pushing the up and down arrows actually turn loudness on and off.
My excitement was diminished after I powered the device down and unplugged it when I put everything back together and turned it back on. Back to sound only on one channel again!
So lather, rinse, repeat of wiping the RAM, but leaving it plugged in, and my settings were retained when I turned it back on from Standby. I have a working system as long as I don't lose power. But the fix is easy enough.
My logic is pointing me to the battery in the microprocessor box. The power in the system on Standby must be enough to store my settings while it still has power, but as soon as it loses power, it reverts back to old settings.
Any other thoughts?
Thanks!
Have you
