Hello,
I have 2 Beomaster 3000-2 receivers but no speakers nor cables.
Can you tell what type of cable I would need to connect from the receiver to a modern-day speaker?
Tony
Hello,
Tony
I recommend you contact Steve from Sounds Heavenly for a set of terminated speaker cables. DIN on one side and either stripped or custom terminated on the other side to match your speaker's needs.
