Beomaster 2400/1900
Hi all, i have a beomaster 2400 and a Beomaster 1900.Not having the best of luck at the moment with my bombaster. I have just had a look at my 2400 and 1900 for the first time.Neither of them are functioning properly. The resisters on the Beomaster 2400 were burnt when I bought it so I replaced them and replaced The two Darlington’s and the resister. Comparing both models which I find easier to troubleshoot the 1900 light is stuck on standby. The Beomaster 2400 flicks on for a split second and off again. All lights are working and all the remote buttons work activating the correct bulbs. My thinking Is there must be a serious problem still. I have one of Martins kits, which I shouldn’t use yet, as perhaps adding capacitors etc…at this stage will make diagnoses more difficult. I have read quite a few archival forums on these issues. Any advice welcomed.
Check for DC on the speaker outputs - even if only possible during the brief moment it comes out of standby.
Will give that a try. It literally flashes on and off. And it clicks without the lights if I press any button again before a few seconds have lapsed
