Hi all,
I am new to this forum, I hope I am posting this question in the right section of it.
I have this Beomaster 2400 with some issues.
The bass and treble sliding pots are broken. They missed the small metal pieces linking the center with the sides, so I assume they can not be repaired. I don't have the schematics of the amplifier, do you know the specs of the posts in terms of how many kilohms they have and if they are log or lin?
Is there any way to replace these pots with something similar in the market? Is it possible to find the original ones at an affordable price? I live outside of europe or the us....
I am against placing external controls for this functions, that would be a terrible thing to do.
The other thing is that three lamps are burnt: bass, treble, balance. The others work fine.
Where can I find instructions on how to replace them? I opened the amplifier from the bottom and from the top according to the instructions of which screw to take out, but I couldn't reach the lamps. I didn't want to keep going further taking out morre screws from the boards, I can see everything is really tight. Maybe there is a way to remove the lower upper pannel and the lights will be right below with easy access, but I didn't find the way.
Thanks a lot in advance for your help!!!!
