Hi Beolover I recently got a beomaster 2200 that suffered during the transport, the buttons do not pair well at the start. Question there is the construction difference between beomaster 2200 and beomaster 2000, I chose between the two difference making the double price at auction.thanks
Beomaster 2200
Not sure I understand, but if you ask about Beomaster 2000 and 2200, - yes they are very different.
Thanks DDillen I had the opportunity to choose between the two and now I am sorry that I did not take beomaster2000.B2200 does not have loudness so I understood that they differ in construction but as musical power are appropriate. final has, anyway it sounds good on the music and 2200 thanksHow much is damaged?
Can't it be repaired?
Photos?
Hi the problem B2200 is on the keyboard that is harder to connect, suffered in transport, I received it from the Netherlands in perfect functional rest. It differs on the final floor B2200 compared to B2000.2200 does not have loudness and this bothers me thank you
Beomaster 2200 has permanent Loudness. It cannot be switched off.
Okay thank you so much for the B2000 construction which is better??2200 vs 2000 thanks
Hello to make myself understood I have a beomaster 1900 2; beomaster 2200; beocenter 7700.A and give up the B2200 in favor of B2000 Type 1801 worth the investment thanksPlease Log In to Reply
