Noobie here in the Beoworld :)
I purchased from ebay a broken Beomaster2000 Type2911 Sern. 2872003
The unit is in really good condition, it turned on with a relay click and all the sensor buttons and lights are working.When i press the front "Programming" the lid opens automatically :)
Here comes the tricky part:
I get no noise from the FM input connected with 75ohm areal antenna. All the 5 station are complete silent, when i try to tune in there is no buzzing sound or tuning light.By changing to TP or Phono i get a low ticking noise. I connected a music player over the 7 DIN TP input and can hear music, but it is low volume, distorted with the ticking noise.Volume up and down is making a small difference,muting works.Bass,balance and treble seem to work also.
I took the unit appart and from visual inspection i can see no bulging or leaking caps.On the power input board i started to change a ROE 470mf cap, my component tester showed spot on value and low ESR on this one.
So i'am not sure if changing all the ROE and electrolytic caps will resolve the issue, maybe i have 2 faults no FM tuner and problem in the Amp section?
What should i do for further troubleshooting and repair?
Thank you for your help.
