Beomaster 2000 (89 model) with S55's
Hello,
Any advise on the following issue.
I have the above combination. Its quite awesome with the tuner operating. Ive connected an NAD , CD Player to it and the quality drops off, dramatically, so does the max volume.
Can anyone help with this?..could it be a component matching issue eg CD player input characteristics ?..
Im probably going to find an B&O CD player , if thats the solution. The NAD CD player is quite a high quality unit.
Thanks for any tips on why this would happen .
Regards
Michael
Sounds like you're connecting the NAD CD player to an output on the Beomaster as opposed to the input. If your cables are wired for both input and output, try changing the connections over! I have a bunch of DIN cables which are wired the wrong way round - incredibly confusing, an I fell for it just the other day on my Beomaster 6500!
Thanks Alex, will try that.
