Beomaster 1900 2 malfunction
Hello I am new to the forum and thank you for accepting me. I recently bought a beomaster 1900 2 with problems and I need a troubleshooting scheme. His problem is, the band and phono inputs are not functional, no sound is heard in the speakers, but the radio works well. I mention that I do not understand electronics I am passionate and help a friend in solving problems. We don't really know what to start with, if maybe a little help from you would be welcome, especially after we opened the station, we realized that we need a connoisseur to guide us in solving the problem. . Excuse me long post, I don't know English, I use Google translate thank you.
What are you connecting to the Tape and Phono inputs?
Are you sure you have cables using the correct pins in the plugs?
Hi DMartin I connected the signal cable correctly on the tape and nothing is heard even on the headphone jack thank you
Correct cable?
Some cables only carry signals one way (f.e. cables for record players, that cannot record).
Try switching to Tape without anything connected there, then insert an end of a paperclip into the pins at the TAPE socket one by one.
Listen for a buzzing or humming sound.
Hi I put in each leg of the tape and phono jack and also does not pull out a whimper. He is also my electronic friend with me and any advice is welcome and helpful, if you can sketch for him because it does not fit what I have found us on google thank
Hi. I would like to help you a lot with your advice in troubleshooting my device and a technical diagram, because it is very difficult to walk there without proper knowledge thanks D Dillen
Hi the technical diagram and your help would help me to solve the beomaster 1900 2 problem. Thanks D Dillen for your patience with the novices ..
Hi I come back again with my problem because I have not been able to solve anything, I can not get a signal on tape and phono and no skilled craftsmen are not in my country. they tell me they can't help me, being too complicated with no spare parts available. If anyone has encountered the same problem that my little advice or help would be welcome thank you. Question for D.Martin ?? made models of beomaster 1900 2 with remote control, I found something in the forum here about batteries for the remote control which included the 1900 series 2. Thank you
Hi, I'm new to this forum and I got B&O virus. I didn't manage to solve the problem with the Beomaster 1900 2 and left it as a future project. I bought a Beocenter 7700 instead with the box and integrated pickup. Are these devices as construction and reliability? Thank you. His problem is: the cassette, radio and amplification part is ok maybe it requires the old belts changed, instead the pickup part came without the dose and belt plate. it fits from beogram models 1700 or 1800 or only 7700 is compatible, other models that correspond to pickup. I wait for opinions and suggestions to my problem or try spare parts ebay thank you,
I have the correct belts for the tapedeck and turntable in your Beocenter7700.
PM or email me.
