After 15 years I have at last managed to obtain the parts necessary to repair my beloved Beomaster 1700. Unfortunately, in the interim I have collected a number of CDs, which cannot be played on my Beograd Cassette player. Is it possible to plug a B & O CD player into my 1700, and if so is there a particular model I should look for?
Beomaster 1700
There are two Beomaster 1700s though I am sure you mean the later one with the tractor bands as the other is a tuner. I would get a Beogram CDX - it is an interesting machine in that it is a 14 bit oversampling unit but it sounds wonderful - warmer than some of the machines that came after and is not remote control. It will need an adapter as it has a fixed lead with phono plugs but you could get the connector, originally made for the 1900/2400 which plugs into the tape input and allows you to attach both the CD player and tape player and choose which you want to listen to via a switch on the connector.
Edit : I found the link!
