Beomaster 1200 rg Beogram not working
Hi everyone,
I have just purchased a beautiful Beomaster 1200 rg but unfortunately the Beogram doesn't work.
I believe it should be a Beogram 1000, and the previous owner said it was a problem with the motor.
I have absolutely no idea where to start, so please can anyone advise about where to start when attempting to solve this problem?
Many thanks,
John
I will put some pictures on later!
Welcome to Beoworld !
What are the exact symptoms?
Most of these decks will need fresh oil pressed into the motor bearing material, a new belt and usually also a new idler wheel.
The latter two are easy, the motor bearings a bit more involved as they are Oilite type bearings.
But doable.
