ouch ! sharing same defect ! 😉
W.Frankenberg wrote:
If you press the AFC button, the tuning will go through the entire FM band, and sometimes FM1, 2, 3 will play the same station, even though they are set to different!
Seem pushing preset or FM doesn't change result , maybe a common wire/connection in these button ?
each button should give a different voltage to IF ; seem don't close the loop
What about at the point I have highlighted ?
Think at point 2 , a partial resistance will read , enough to keep some fm but not enought to have correct level ...
Login to view image
I will try to look at these
I did not try pushing afc , but this night when I'll be back from work I'll give a try .
I'll keep you informed if I found the mistake, but you may be faster!?!
wiil be great , I have 3 amp on the bench with ghost problem ; maybe some help each other will solve .
By the way, your woodwork looks good, but you also have every special tool at hand !!
Yes , I like to be indipendent (where I can) ,so some years ago to make some plinth , I bought this Bosch table .
From a woodworker the simple thorens 150/160 plinth will cost half the Bosch . Some practice , and voilà ; usually just frame but sometimes some furnishings as well . Just for fun
