ok, FM ZF could not translate google correctly😧
This means the IF of 10.7 MHz
The Zehnerdiode in the power supply to the 100k tuning pots but is also very important, it determines the tuning range of the FM tuner, the voltage is not correct here and constantly the tuning range is too high or too low, meaning you can then only stations below 88MHz or received above 108MHz!
I noticed there is a note in a service manual Beomaster 1200, there is a modification for the FM area.
in some older devices, no 3.3k resistor was connected in parallel with the STEREO lamp!
If the bulb had blown, it came to the deteriorated and distorted FM playback, up to the failure of FM!
do you have maybe a device from this old series in front of you?
Then you should check if the STEREO lamp is ok!
No joke I tested it on one of my Beomaster1200 without this 3,3k resistor parallel to the lamp, without the bulb there is no FM reception!
Incidentally, I also have a small problem with the STEREO display on the BM 1001; if I switch to TAPE or PHONO the lamp does not turn on, is that the same with yours? On a BM1200 it lights up!
