Beomaster 1000 + Beogram 4004 Pin question
Hi all, I've enjoyed my Beomaster 1000 for a few years and today bought a Beogram 4004 tt to go with it...only to find out the tt has a 7 pin connector and the beomaster a 5 pin input. Is there an adapter that would solve that problem? Ty
On most (but not all) Beograms and Beocords with a 7-pin DIN plug at the signal cable, the two outer pins (6 & 7) can be unscrewed from the plug using a very small (watchmakers) screwdriver.
Keep the pins in a safe place - you will need them when you replace your Beomaster 1000 with a Beomaster 2400-2 and want to remote control the Beogram.
Thank you! It worked!!
