Beoliving Curtains
What is the easiest solution to control curtains with your beo 4 or Beo 5 ?
Thanks ;-) Jan
You will need a TV with cinema control ( System 3 based/BV7-40 Mk3 or BV7-32 with cinema module) a 12v power supply and relay drive, and motorised lutron curtain rail or similar.
In english ? :-)
Which TV do you have - and I'll tell you if it's a none starter or not...
Lintronic is also an interesting option
Lintronic website
Relay-108, for controlling lights, curtains, and so on.
That Lintronics system seems interesting :-)
But quite difficult to understand :-( I wish I spoke better English
Which language do you prefer / speak ?
(some information is available in other languages,
and there are lots of people that will be willing to help ! 🙂  )
The problem isn't really the language but I'm not very technical :-)
 I just want to know what to order (i don't have a beosystem 3/cinema thing) but I would like to close the curtains with a Beo 5. From what I understand I will need a Lintronic box and a motorised system for curtains. Is this correct?
And secondly witch motorised system LOL.
Thanks !!!
Or If you speak dutch you can always send a PM offcourse
Yes, you can use several products from Lintronic which can do that,
i will send you a PM in Dutch 🙂
