puzzomio wrote:
Now. I understand, I try to connect my iphone x with 3.5 audio cable to beolit, the mute button is always disabled you ask me to try to activate?
I just ask you to try different things to play around with it
Why not do a few simple tests:
If the time is now say 11 am, set an alarm for 11:05 and try:
> with 3.5 cable plugged in
> with 3.5 cable plugged out (remember to make sure you are connected to it)
> with 3.5 cable plugged in and mute on
> with 3.5 cable plugged in and mute off
> with 3.5 cable plugged out and mute on
> with 3.5 cable plugged out and mute off
Maybe it might reveal something?
I think on the video they don’t have a 3.5 cable plugged in but they are connected to it via BTooth.
Good luck my friend
