I have buy a beolit 17. The sound is very good and full. But when the speaker is on , there is a continuous humming/white noise. When i listen relaxing music/jazz/classical music at the evening and the speaker is close to me, i found it irritant. The humming is not more loud when the volume is higher. Is this a defect in my speaker?
Beolit 17 humming/white noise
Your beolit is likely defective. None of the B&O multiroom speakers I have any hiss I can hear at any volume level. The power supply could be damaged or defective.
I have the same humming / white noise with the beolit 17 audible at low volume or when you pause the music, even if there is no phone connected to it.
It almost stops once you set the volume to 0, but once you go to 1 it will be the same till max volume.
Maybe someone else with beolit 17 can confirm if this humming is “normal”?
@cedricm did you return the speaker or sent it to be checked?
