Beolit 15 Only works while charging
Just opened it from the box, charged it up, and then removed it from charged and it worked normally. But the next time I put it on charge, it would not work if it’s not charging. Even if I unplug it while it plays music, the speaker just turns off.
Any tips to fix this issue?
Try new battery
The thing is that I opened the box after a month of receiving the speaker. Can I still return it? I ordered it on amazon
In the US you have 30 days to return with Amazon. So as long as you start the process before 30 days...
