Beolit 12/15/17
Am i the only one who’d love to see a new Beolit? Same form factor as the 12/15/17, but equipped with ac wifi and airplay-2. Should be a low hanging fruit for b&o. Anyone heard rumors about some device like this?
Did you see the upcycle that me and Tuomas did?
We took a Beolit 12 apart and replaced the WiFi card/airplay module with a Google mini.
You can get a Beolit 12 fairly cheap these days.
Ver cool. Would love to see the step by step instructions.
The Beolit 12 sounded great, but the wifi/airplay card was just pants.
Agree, this is really cool! I even have a much beloved beolit 12. Unfortunately not a fan of google chrome. If possible to replace for a better wifi card abs get AP2 to work, this would be fabulous.
If I get a hold of another one, I will make instructions.
I've tried to "airplay convert" various B&O devices, including portable ones. In that cas the main problem I ran into was Power : Aiport bases are main powered and even if you want to tear it down, there's still at least 2 different power voltages with would not make it an easy job.
Did you try to fit an airport express inside?
Not into a Beolit 12. And generally not "into" devices because i didn't wanted to harm the original devices.
I have "Airplayed" a Beosystem 10. I wanted to make it run fully on batteries but I didn't managed to:
https://archivedforum2.beoworld.org/forums/t/36351.aspx
And a Beoplay A2 wich I would have liked to power the Airport base from the USB, to have the wall socket free to charge the A2. But I also didn't get it:
I have an airport express (with airplay 2) that runs of usb power.
I tried to power it from the Beolit 12, but it gives some kind of surge to the audio signal/aux cable.
Yes, they're a lot of hacks to power the Airport express from usb or even à 9v battery.
From memory you need two voltages: 5v and 3,3v.
I tried the hack with the duck power board: 5v directly from USB power and 3,3v via the duck power board.
it did work for a while. after some weeks the AE was fried (not the duck board).
I now have a second AE that died after being in the bathroom for maybe too long; no power at all.
I should open it and plays with the duck board again, but those boxes are painful to open so at the fifth confinement maybe…
