Beolit 12 as wake up system?
Hi
I have a Beolit12 and an older iPod Touch (iOs 6) in a Dock connected to the Beolit via 3,5mm Audio cable.
I was trying to use the Beolit for wake up but do not get the wake up tone (clock app) to the Beolit.
Alternatively I would like to use any other app playing music to wake me up. All ideas are welcome.
Thanks!
Heribert
Did you put the 3,5mm in the dock or in the headphone output?
Into The Dock
Try putting it in the headphone socket. The dock-output is a funky piece of work..
I tried it in the head phone socket - did not work either.
Any idea about an App that can play music and has a wake up timer?
Alarmify
leosgonewild wrote:
Alarmify
Agree
+1 🤒 the best one for Beolit 12
If only apple would let it run in the background, it would be perfect.
Alarmify can use AirPlay. So Heribert, you can get the functionality you are looking for :)
a late reply, I know, but another option would be to use a Beotime which switches the Beolit 12 on with the A.Mem source command at a specific time.
