Beolink Wireless I - Is it Worth
Seems to be a very nice option to transmit and receive the audio signals without having to do a lot of work on wiring the system in a link room. I would like to get some first hand experience on usefulness and cost associated.
Planning to add a pair of Beolab 4000 in guest bedroom with either wiring the Master link or wireless option such as Beolink Wireless 1. I guess the wireless option needs the IR eye..thus adding to cost.
Will I need a IR eye if i connect Beolab 4000 using ML cable to a Beosound 4000.
I don't have a wireless link system, but from what I have heard from my dealer and people here on beoworld, there's a lot of trouble with interference from WLAN's and other electrical equipment.
It's a nice idea in theory, but before I would buy anything, I would ask my dealer if he could lend me a beolink wireless so I could test it.
Yeah my concern would be that when you use the microwave it doesn't work properly.... similar to our other wireless household networks.
Hi sodoi18
I'll give you some positive feedback on the wireless system because I use it very often and it works very well indeed.  I have three units, one transmitting and two receiving.  One receiver is used for the audio channels for the link TV and there have never been any delays or dropouts.  The second receiver gets the NMusic and NRadio from beoport to my older beomasters and that works very well indeed.
I have not had the opportunity to use a large, wired masterlink system so I can't tell you whether it is going to be better or worse or by how much.  My home simply doesn't lend itself to installing a wired system, it's very open plan and has thick pre-cast concrete walls.  If I didn't have the beolink wireless, I wouldn't have a system at all.
Our house uses a fair amount of wireless equipment, the computer network and the Beocom6000 network.  There is also a microwave but it doesn't get a lot of lengthy use, just short term zaps!!  So far, the effects of interference seem to have been minimal but that is just my experience.
I agree with the comment about borrowing a unit for testing, that is the only real way to get to the bottom of this issue.  For me, I am looking for another two wireless units so that I can expand my setup and I'm certain that the results are going to be good.
Regards
Geoff
I'm with Geoff.  I use mine every day, and they work great.  Then again, according to my dealer, I am an exception.  I have wifi, cordless phones and a microwave (not used very much).  It took some time to find a placement that didn't drop at times.  My biggest challenge was people - people standing/walking in the path between the transmitter and receiver often caused it to drop (when the path was long - shorter paths seem less bothered).  To my ears, the sound quality is identical to wired ML (I have both).  Either borrow a pair or make sure you can return them without a hassle as wireless performance is unpredicatable.
Stan
I think you can have a great setup with the BeoLink wireless, but there are a few things you need to avoid:
1. Using wireless internet
2. Using wireless phones
3. Using a microwave
4. Using a cellular phone
5. Speaking loudly
6. Moving too quickly from room to room
7. Wearing shoes in the house
8. Using a vacuum
9. Using a television
10. Using zippers
11. Hardwood floors
12. Tall furniture
13. Extreme temperatures
14. Music with very high or low tones
15. Indoor plants
16. Caffeinated beverages
17. Carpeted floors
18. Halogen lights
19. Using a rescue inhaler
20. Mirrors
21. Winking or blinking
22. Tiled floors
23. Outdoor plants
24. Short funiture
25. Wired phones
26. Non-stick surfaces
By paying close attention to these things you will keep dropouts to a minimum and more thoroughly enjoy your new BeoLink Wireless system!
What about sneezing??
So life in a tent (with skyhook support) or an igloo with solar power would stand a positive chance?
tony
tony
I wish I could say it would be safe, but rustling of the tent canvas would likely cause air molecules to stir irrevocably and thereby lose their ability to carry the signal. As for the igloo you're dealing with low temps (see list) as well as instability of non-traditional electrical sources (best to use their internal kerosene engines for power).
point taken! should have considered before writing - the movement to keep warm in the igloo would apparently not be good either!
tongue definitely in cheek!
tony
