Beolink wireless 1 to Beolab 3500
I'd like to know if i can connect from an audio source in one room to a Beolab 3500 in another room? If so does the BL3500 connect to the Beolink wireless via masterlink or powerlink? Would the BL3500 need any software update? if connecting via powerlink i assume it would need to be a fully wired powerlink? Also can the same connections be made with a Beolab 2000?
Thanks in advance,
Darren
Yes, you can, IF you got newer version without MCL. 2005 and newer? I thought you needed both PL connection and a ML, but according to the manual on the B&O-site only talk about a ML. Maybe the have changed it one more time since 2005. http://www.bang-olufsen.com/UserFiles/File/ug/BeoLab3500/beolab3500_userguide_english.pdf
