I'd like to know if i can connect from an audio source in one room to a Beolab 3500 in another room? If so does the BL3500 connect to the Beolink wireless via masterlink or powerlink? Would the BL3500 need any software update? if connecting via powerlink i assume it would need to be a fully wired powerlink? Also can the same connections be made with a Beolab 2000?
Thanks in advance,
Darren
