Vienna wrote:
3. will work (V.OPT6) **)
**) Limitations of this setup:
- In a B&O wireless setup it is MANDATORY all MASTERS (Video / Audio) and the WIRELESS TRANSMITTER
are HARD-WIRED via MasterLink cable.
- Therefore your TV can't be the Videomaster of your system, it will be just a Link.-TV.
- You will not be able to distribute the sound of your TV (and videosources connected to it) to other rooms.
- Distributing audio from your BSd 3000 to both other rooms will be possible.
Let me see if I understand this 🙂
Using the excellent explanation you provided in another thread, "V.OPT 6 viceolink (slave) responding to videocommands AND audio commands abd send them via Masterlink to video/audiomaster"
So the BV8 thinks it is a video slave even though there is no video master ... and so:
- any audio only commands (e.g. [RADIO], [CD]) are transmitted to the BS3000 and the audio is received by the BV8 and played through the BV8's speakers (and any that may be attached to the BV8)
- any video commands that correspond to the BV8's sources will be acted upon and the audio will come through the BV8's speakers, but NOT be transmitted through to the rest of the house
- any LINK or non-BV8 video source commands will be "lost" or "disappear" since there is no video master to receive them
I think there is a difference here, if the systems were hard-wired via MasterLink cable, then a [TV] command in the BS6000 room would trigger the BV8 and result in the BS6000 room hearing the BV8. So whereas the ML cable is truly bi-directional, the Wireless implementation is only partially bi-directional ?
None the less, this configuration might be helpful in my set up ! So thank you for the ideas 🙂
