Hallo to everybody
I was completing my masterlink connection homework. Thanks to the support I received in the forum, I sorted out my problems with the audio part. Now I have some small issues with the video distribution.
My Video Master is a BEOVISON 8-40 and I would like to get the video on my AVANT 28.
The plan is to bring the RF OUT of the BV8 to the SWITCH Matrix of the satellite that has a Terrestrial input and in this way to distribute the signal over the entire house. Unfortunately during the apartment refurbishment the additional coax I had requested was forgotten. My plan B is to use my CAT 7 wiring as replacement for the COAX ( I found some BALUN up to 900 MHz bandwidth). Before investing on that ( and potentially also on same signal amplifier) , I was willing to test the concept with direct connection of the RF out of the BV8 to the TV input of the AVANT.
I have to admit that the first tentative was not successful ( I have some doubt on the cable I used as it may be 50 Ohm instead of 75) but also I am not sure if the RF out will provide a signal strong enough for the TV input.
In addition ( due to the room set up ) it is very difficult to identify the correct input on the AVANT. ( I have to plug the connector trusting my hand )
I do not use the TV input since a while ( only sat receiver) and I have two connector close to each other . I had assumed that the FEMALE is the TV and the male is the RF OUT of the AVANT.
Any suggestion is extremely welcomed.
Regards
