joeyboygolf wrote:
Sounds like you have thrown everything up in the air and connected them in the order they landed!
The powerlink wont work in this configuration as it has no two way control capability.
This would work:-
BS2500->Aux link cable->1611 converter->ML cable->Passive with eye->Passive speakers
Of course this is the most elegant way - not only ๐ because I recomendet exactly the same solution a few posts earlier !
Mark, DON'T COMPLAIN, please READ CAREFULLY when some quite qualified members try to help you !!!
AND PLEASE MENTION ALL DETAILS OF YOUR SYSTEM - TILL NOW you never mentioned you have a TV
connected to Aux!!
By the way, this problem can easily be solved using a DataLink Splitter-Cable to connect TV AND BeoLink Converter
to the same 7 pin socket of your BC 2500
SORRY - I HAVE TO REPEAT MY PREVIOUS POSTING:
Blackrix described one possibilty, I described two alternatives
- each one has it's own advantages & limitations but all three will work.
Each one will only work within it's own context regarding COMPONENTS AND CABLES!
