a11mcr wrote:
Graham, what would the differance be between the fully wired powerlink cables (i thought they were only for the display on the pentas and such like) but i will try one (if i can find a spare) and let you know.
mark
If you are not using a Mk2, sometimes called a "fully wired" powerlink cable, it absolutely will not work!!!!!!
You can use any transceiver you like as it is irrelevent.......
I have banged on about this since the beginning of BeoWorld, answered many, many posts on the subject, does nobody read them?
If you are not using a Mk2,sometimes called a "fully wired" powerlink cable, it absolutely will not work!!!!!!
This is absolutely the last time I will post on the subject.
Rant over.
