Hi! Is there a way to reset bass, treble and loudness settings on a BeoLink passive back to factory default?
Regards Rasmus
Regards Rasmus
I assume you've read the passive manual? as it says to reset your sound adjustment you press LIST to display RESET then GO. BUT this only works if the volume settings haven't been stored.
If the volume settings have been stored then i dont know how to reset back to factory setting, but i would be inclined to unplug the Passive Amp for an hour and see if that works.
Let us now if that works as ive stored my volume settings and it would be handy to know.
Do you have the manual as there is a whole page on sound settings.
Cheers.
