Beolink gateway firmware upgrade problems.
Hi
I recently bought a second hand BLGW which has v1.0.0 firmware on it. When I click on “check for latest version” I get a message “Error while connecting with update server (Invalid credentials)”. Anybody know what I am doing wrong or what the problem could be?
Huw
huwtec wrote:
Hi
Huw
Hello
Check it’s on DHCP
Check the time and date are correct
Failing that contact ticket via beointergration.
I had this problem on mine years ago and it was something on the server which was fixed for me
Hi Seanie
Thanks for the reply. I did have it set up on a fixed ip address but have tried it on DHCP as you suggested but still no success. the time and date are correct and updated automatically. I have contacted beointergration and am waiting for they're reply.
Did you manage to get your BLGW to update the firmware?
//Andy
