BeoLink Gateway
I could not download the press release from the B&O site (why?), but you can find more here:
http://article.wn.com/view/2014/02/04/04022014_Bang_Olufsen_targets_growing_integrated_home_techno/
In the article on another website there is a picture of the device, but it is rather small. You can't recognize the connections of it.
I guess this is going to succeed the MLGW - but can it be used instead of the NL-ML-converter as well?
Does anyone know more?
Greetings Millemissen
*** EDIT by Dillen
Beoworld Moderator
Yes just seen it myself. Sounds very interesting,wonder what the price is?
Agree, it looks very interesting.
So, the MLGW becomes obsolete? I thought about getting one but after reading that...!?
Or will a MLGW AND a BeoLink Gateway be necessary to combine old ML and new NL systems?
I think that is the same, but without Masterlink connection.
So we need a NL-ML converter also to make the "old " ML system to integrate with it? Not the MLGW and the new Beolink Gateway connected together i suppose?..
Edit:
This is what they say about the connections:
"At first glance, BeoLink Gateway is an unassuming affair with just a few connections: Master and Network Links that connect to Bang & Olufsen's own BeoLink ecosystem, and Ethernet and USB ports that connect to third-party control systems and devices."
So this also works with the old ML system 😁
So no need for the NL/ML-converter any more?
My quess is: No, there is not! (if you need the 'homeautomation integration' in your setup).
But my guess is also that the price will be above that of NL/ML-converter....
....because it has the functionallity of the MLGW and the NL/ML-converter combined in one device.
Looking forward to futher information.
By the way - did anyone notice that the BSys4 was 'announced' as well - probably because of the new/additional 'cinema solution' feature!
This isn't a NL/ML converter, you can connect the ML if you have a ML network or the NL if you have an NL network. But this is in no way a converter.
The ML Gateway had the 2 connections as well and wasn't a connector.
Where? Link please!
