Beolink Converter NL/ML to Beolink Passive
Dear Forum
I have:
• Beosound Essence mk2 with Beolab 8000
• Beolink Converter NL/ML
• Beolink Passive with a set of BeoVox CX50 with a Beo4 remote
I want to integrate the beolink passive as a part of the multiroom setup and play sound from the Beosound Essence on my Beolink Passive. How to set this up??
How should the setup be?
• A Master
• AV Master
• V Master
• A Slave
• Source Center
Or are there other setups I need to make? Maybe something about the beo4 commands?
Thank you very much! ☺
Thanks mate - nice, great idea.
But what if I want to connect my Beovision 8 and play the sound from the Beosound Essence though the speakers on the Beovision 8?
Unfortunately does it not work either. When I push radio on my beo4, the television standby indicator goes from red to green and short after goes to standby again.
Normal 0 false false false EN-US JA X-NONE
Maybe I should reset the converter? I have bought it second hand, where there was an old setup.
Sources visible on ML
Tv and so on gray and not to choose.
Radio and so on said empty. I have changed it to Beosound Essence MK II and tunein.
But that did not help.
Ir mapping says radio Beosound Essence MK II and tunein.
What to do now?
Yes, it is saved and also I tried to restart. I can upload pictures of the screens on the beosetup, for the converter but also the essense.
excellent idea
