Hello,
Could somebody give me the link to, or send me, the Beolink converter NL/ML manual that explains how to configure it?
Thanks in advance.
Didier
Hello,
Thanks in advance.
Didier
http://www.bang-olufsen.com/en/customer-service/product-support/accessories/beolink/beolink-converterHello, Could somebody give me the link to, or send me, the Beolink converter NL/ML manual that explains how to configure it? Thanks in advance. Didier
Hello,
First, thanks for your answer.
But I am looking for something more detailed. Is it something you plug and it works? No configuration needed?
Kind regards,
Didier
Thanks for the document.
I really appreciate.
Best regards,
Didier
mjmedio,
Thank you for this link. I have been waiting to see this document for a long time. I now know why the converter is priced at around $1000 USD.
It use to be that a Bang and Olufsen system regardless of price was relatively easy to setup for the average user. This is not the situation anymore.
Don't have MLGW but control my Converter (with speakers attached) via B&O smartphone app (no IR) so can't imagine MLGW would be any different?I meant if the BL/ML converter (BLC) count be controlled by MLGW in the same way as a Beolink active can when you have attached speakers to it. Or is it only IR control that is possible?
