Beolink converter NL/ML manual
Hello,
Could somebody give me the link to, or send me, the Beolink converter NL/ML manual that explains how to configure it?
Thanks in advance.
Didier
doun wrote:
Hello,
Thanks in advance.
Didier
http://www.bang-olufsen.com/en/customer-service/product-support/accessories/beolink/beolink-converter
Hello,
First, thanks for your answer.
But I am looking for something more detailed. Is it something you plug and it works? No configuration needed?
Kind regards,
Didier
Thanks for a very good document. I have two additional questions that I couldn't find an answer for.
1. Is it possible to control the BLC from the MLGW if you connect speakers to the BLC (and use it as a Beolink active)?
2. Can you send the AUX (line in) to the ML and listen to that source in other room (for example Beolink active)?
The BLGW will not act as an active type system similar to the NL converter.
You can share the source from a NL converter to a ML based system as long as the source name isn't already in use on the ML system.
Thanks for the document.
I really appreciate.
Best regards,
Didier
mjmedio,
Thank you for this link.  I have been waiting to see this document for a long time.  I now know why the converter is priced at around $1000 USD.
It use to be that a Bang and Olufsen system regardless of price was relatively easy to setup for the average user.  This is not the situation anymore.
Thank you for this mjmedlo!!
I meant if the BL/ML converter (BLC) count be controlled by MLGW in the same way as a Beolink active can when you have attached speakers to it. Or is it only IR control that is possible?
Don't have MLGW but control my Converter (with speakers attached) via B&O smartphone app (no IR) so can't imagine MLGW would be any different?
