Beolink converter 1614
Hi Beofans,
How can i know if my Beolink converter is working ?
I tried to use it between a beomaster 5500, or beomaster 7000 and a beolab 3500 :
audio aux link from beomaster 5500 to converter and ML from converter to BL3500,
or powerlink from beomaster 7000 to converter and ML for converter to BL 3500
But it didn't work.
Thanks for your answer
Theo
You can’t really - apart for when you hear it.
The golden rule of thumb = alway power on the converter as the last device when you have set things up.
You should remove all components from AC power.  Connect the Audio Aux link from the 5500 to the converter, then Masterlink to the BL3500. Connect power to the 5500, then the BL3500, then the converter last.
