Tim84 wrote:
hi Lawrence,
even when i try to connect a Beosound core the volume is so low that i have t set the volume of the to to Max to hear something. Am i doing something wrong or does it have to work in general? I use a five pin aux cable that works perfect on my ouverture.
Current System
Livingroom: BeoVision 7 MKV + BL7-2 + 2xBL 8000 + BL 2 + 2x BL 4000; BeoSound Ouverture Bedroom: BV 7-32 MKIV / BL7-1 Kitchen: BeoPlay M3 Bathroom: BeoPlay M3 Entrance: BeoPlay M3
Hi Tim,
Indeed, there may be something wrong with your 1611. I’m afraid I’m not technical enough to advise further on that.
The fact that the cable works between the Core and the Ouverture’s (Aux?) input suggests that it is fine.
The last thing I can suggest: when you connect the Core to the 1611’s Aux input, configure the Core to give a fixed level output from its Powerlink sockets. If the menu options allow, configure this to be as loud as possible.
If you can’t find this configuration option, again, turn up the volume on the Core to somewhere near the maximum (at least 75%).
Good luck, sir.
Lawrence
