Beolink app crash with IOS 8.3
Sorry, silly me - misread the name of the app. :/ You guys have trouble with Beolink app and I referred to Beomusic app.
it coincided that I had some issues too with the standby mode.
Hi
The App is working until i press the standby button then it crashes. Hope the will fix that already reinstalled the app no change.
every  button with confirmation does not work!
Is there a support site at b&o for complaining ?
What suggestion?
This is an product fault. No product Development.... As it is now the Beolink app is totally useless.
These things happen when you early adopt iOS updates. In the future before upgrading you may want to consult with B&O direct or your dealer to avoid having to wait on the patch. Most integrators will tell you never to update unless you speak with them first. Don't panic there will be an update rolled out to fix it all. I would imagine that is the same update that will enable some of the features that were added to the BLGW from it's latest update.
Ok, all other of my app works as they should and IOS is updated several times a year but in the future I will give BO some extra days before I update IOS to newer version.
It will be interesting to see how many days it will take to solve the problems this time.
I talked to BeoCare yesterday.
They are aware and are working on it.
I accidentally upgraded and am stuck too!!
