Beolink app crash with IOS 8.3
Hi, I installed IOS 8,3 yesterday on my Iphone 6 and suddenly the standby button on the beolink app will not work. When I push the standby button no matter on what sources is used the result is that the Beolink app crash and I have to open it again and no standby signal is sent. Is there anyone else who has got this problem?
I tested BeoSetup and BeoPlayer and they worked fine. Even initiated BeoMusic without issues but then I have no devices that are supported by it. Might just be related to link functions.
I have the same problem
Hoppfully BO solve this really quick. The Beolink app is useless as it is now.🙁
YepCrashing when I hit the standby button
Works very good for me with Beoplay A9 Mk2 since two days ago.
But only after I updated A9 I think. Before it did work but with many difficulties: didn't wanted to send it to sleep, didn't wanted to wake it up, long reaction delay on command etc.
Running it on the iPhone 6 with iOS 8.3 (just to reconfirm that).
Are you using the beolink app for the gateway?
Works very good for me with Beoplay A9 Mk2 since two days ago. But only after I updated A9 I think. Before it did work but with many difficulties: didn't wanted to send it to sleep, didn't wanted to wake it up, long reaction delay on command etc. Running it on the iPhone 6 with iOS 8.3 (just to reconfirm that).
No, just directly controlling A9 over home WiFi. Could it be the gateway then?
I did not know that you could use the Beolink App to controll other things than MLGW or BLGW or do you mean another BO app? The one that is not working for Me is the one named "Beolink" app controlling an MLGW.
