Sorry, silly me - misread the name of the app. :/ You guys have trouble with Beolink app and I referred to Beomusic app.
it coincided that I had some issues too with the standby mode.
Hi
The App is working until i press the standby button then it crashes. Hope the will fix that already reinstalled the app no change.
every button with confirmation does not work!
Is there a support site at b&o for complaining ?
What suggestion?
These things happen when you early adopt iOS updates. In the future before upgrading you may want to consult with B&O direct or your dealer to avoid having to wait on the patch. Most integrators will tell you never to update unless you speak with them first. Don't panic there will be an update rolled out to fix it all. I would imagine that is the same update that will enable some of the features that were added to the BLGW from it's latest update.
