Good day all,
I have a Beoplay A9 mk1 which I love! I use it half of the time with it connected with airplay on my phone and the other half hooked up to my record player. I would love the ability to adjust the volume and switch back and forth with a remote.
I had heard the Beoplay A9 mk1 works with a Beo4 but also heard it works with the legendary Beolink 7000.
1. Does the Beoplay A9 mk1 work with a Beolink 7000?
2. Has anyone used the Beolink 7000? Any advice on day to day use would be appreciated.
3. I plan to get the entire Beosystem 7000 eventually, would the Beolink 7000 be better then the Beo control panel?
4. Is the Beolink 7000 touch screen glass kinda like an iphone or do the buttons actually have a feeling to them if that makes sense.
Thank you all!
-Field
