Hi Beoworldonians,
I'm looking for some help with my Beolink 7000. I've already had great success getting the BG7000 working well and should have the Beocord working as soon as I get the bands delivered to me again all through the great help I've received here.
What I need to do now is get my Beolink 7000 back in shape and my first issue is the front glass panel is coming away from it's clear plastic mounting which holds the square nuts. For some reason the glue in one corner has failed and the plastic is detached from the glass in that corner. What I'd like to do is glue it all back together again but I have no idea what glue was used in the first place and whether superglue is the right way to go or whether someone here can recommend something better.
Once that's done I'll replace the battery pack (already tested externally - works well) and try to manufacture a new mounting plate/bracket for the desktop charger along with some more sturdy contacts. The old one seems to have melted probably due to the last owner installing the wrong kind of batteries in the unit and this in turn has made a mess of the contacts. Again if anyone has any experience on what works well and what not to do, I'd be very grateful.
Cheers
Peter
