Beolink 5000 key sequence to cancel timer…
Thanks Stoobie,
The manual refer to action following displayed messages. Thats why I need a blind sequence…
A shame the display can't be fixed, this remote ans particularly the one I have is in a so perfect condition, I would like to have it working.
I should read the whole posting first 👍
Stoobie
Exeter,
Devon,
UK
matador43 wrote:
Hi was gifted with a beolink 5000, perfect to cancel a timer on my haunted BS2300.
So, all you want to do is cancel the timer function, right?  I seem to recall this trick:  When your Beosound 2300 is in 'standby' mode, press the 'mute' button on the Beosound (not remote).  That should cancel the timer (if I recall correctly)
Good luck....
Hi MediaBobNY,
This is a common misunderstanding: pressing mute when standby, just mute the speaker but keep the timer active.
If in standby, the Beocenter turns on if but the speakers keep quiet, If on playing any source it switch to the timer programmed source, in my case, radio.
Guy wrote:
matador43 wrote:
So thats "stream" of 5 keys, right? Is there something I need to do, or time i have to wait between each round?
Yes, just press the 5 keys one after the other.  Wait a couple of seconds and then repeat.
If you do check the BC2300's IR transmitting, it should look like this when the lights flash:
Hi, Guy
I've entered the sequence several times in a row with pauses in between.
The BC2300 sensor did indeed react (visible from the naked eye) as follow:
PROG - No flash
DOWN - No flash
PLAY - No flash
STATUS - Flashes
CLEAR - Flashes, wait 3 sec and new stream of flashes.
I'll report after 12h30 🙂
^ That's the same flash sequence as mine - and I didn't realise that it is just visible with the naked eye!
Fingers crossed for 1230! 🤞
Didn't work today.
I will wait the whole week to see if it only cancelled some ones…
A thought: Perhaps the BC2300 was set to RECORD rather than PLAY at 1230hrs every day?
This is a bit more complicated to clear, because there are more options depending on whether you are recording to A.TAPE or V.TAPE - and of course this assumes that system was part of an interconnected system in the past.
I am guessing slightly, but I think to clear an A.TAPE recording timer, it would be as follows:
PROG
PLAY (Edited - I got PLAY and DOWN reverse when first posted, sorry)
DOWN
STATUS
CLEAR
And to clear a V.TAPE recording, it would be:
PROG
PLAY
STATUS
CLEAR
I have tested the above A.TAPE recording timer clear with my BC9500, and that sequence works.  It seems to function the same on the BC2300, but obviously doesn't find anything when I press STATUS.
Then if i follow you well :
I may first try :
PROG
PLAY
DOWN
STATUS
CLEAR
Meaning like initial scenario but with the correct sequence?
And if it dont work try the second sequence?
The "recording timer" makes sense! I mean who awakes avery day but saturday at 12h30? 😁
Anyway. I will enter the sequence tonight and get back as soon I get a result.
Thank you Guy for the time you're spending on this !
For clarity:
As posted on 18 Jun, to cancel a PLAY timer the correct button sequence is:
PROG
DOWN
PLAY
STATUS
CLEAR
But given that this didn't work, I am guessing that there is a RECORD timer set.
To cancel an A.TAPE record timer, the correct button sequence is:
PROG
PLAY
DOWN
STATUS
CLEAR
And to cancel a V.TAPE record timer, the correct button sequence is:
PROG
PLAY
STATUS
CLEAR
So given that you have tried the first sequence and it didn't work, try the second and then the third sequence.
Of course, depending on the state of the internal battery the clock on the BC2300 may be incorrect if it has sat unused for a while.   Hence 12h30 may not have been the original intention.
