I have a beolink 1000. After a few days the batteries are empty. I've opened it, bur everything looks "OK", I can't see anything suspicious. What's wrong?
Beolink 1000 battery leak
Keypad button stuck down? Can you check if the IR is sending constant signals by looking through a digital camera at the IR emitters. You'll see it flashing with a signal.
See my posting 1/2 way down this thread. It is not dealing with your exact issue but it might reset/clear the issue your Beolink 1000.
Exeter,
Devon,
UK
Devon,
UK
