Beolink 1000
Me ma's BL1000 has given up the ghost, checked /changed the batteries, checked voltage out of battery area and into the pcb and across the capacitor, checked terminals connecting wires board to battery area etc all ok, anything else to look for - it apparently just stopped working - kaput or what?
salut
tony(now in uk and it does seem cold here)!
Is there any dirt under the contact foil? Water, salt, dirt, CocaCola, beer...
It's possible, that the BL1000 thinks, there is a button activated all the time.
Just what I was going to say. I had the same problem with A Beolink 1000 a few years back. Cleaned it and it has worked perfectly ever since.
Tried that still no joy - tried pressing all buttons - all seem ok
more?
t
Did your ma get a plasma tv set recently.... Those disturb the reception for b&o signals.
Had this issue trying to control an Beocenter AV5 that was close to our plasma TV.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
no just used to control an Ouverture and an MX5500 ty
t
It reminds me of getting my Beovison LX5500 from an auction some years ago.
The Beolink 1000 did not work but I could turn the LX on by the buttons.
I went straight ahead down to the nearest B&O shop and got the print replaced.
The LX and Beolink 1000 still works to this day.
stotty1111 wrote:
... it apparently just stopped working - kaput or what?
... very likely!
Tony, replacing the main-pcb (OrderNo 8007900) and, if it's a pre MKIII BeoLink 1000 ´
(STEP <> instead of arrow UP/DOWN to change program/title)  also the set of buttons
(OrderNo 2776010)  should be the solution  ...
If you use a digital camera or camera on a cell phone pointed to the IR end of the Beolink you should see the LED's flashing. At least that will indicate if there is a "stuck" button or any life at all when a button is pressed.
Have you tested the two capacitors inside?
Here is a posting I put on the Yahoo Beolist sometime back and the solution. Please read the postings from the bottom one up!
Hope it works for you.
Re: Broken Beolink 1000
WOW success!! - it worked brilliantly. Thank you so much, that was
great. To think, I had forgotten about Beolist and haven't been on
here for months.
Thank you
Stoobie
--- In
link, "Frank" wrote:
> Try this:
> Get out the batteries and short-circuit the + and – contact of
the
> battery holder in the BL1000. Put the batteries back in and try
> again. Some Duracell batteries have very small positive contact
> tips. They give bad contact and cause the microprocessor to crash.
> Success
> --- In , "stoobie_too" <sbs@g...> wrote:
> > Last week my Beolink 1000 was working perfectly. It stopped
> working
> > one night and I assumed the batteries were running low. I
replaced
> > them with new Duracell but it still does not work. I am the only
> one
> > at home so it has not been dropped or damaged. I was using it to
> > teach my new Pronto Remote all the B&O codes.
> > Have I pressed a button combination that has stopped it working?
> > I spoke to my local dealer who says they do not repair Beolink
> 1000
> > but only do a trade for a refurbished one. At £95 it is quite a
> > lot. (I have just had my Beolink 5000 repaired at a cost of
£150
> > so I do not need the extra expense, but find remotes in all the
> > rooms helpful)
> > Any "Techies" out there who can suggest a solution?
> > Thanx
Exeter,
Devon,
UK
